cmake_minimum_required(VERSION 3.1)
project(dde-file-manager-lib)
中 cmake_minimum_required 其中 cmake_minimum_required、project
set(DFM_LIB_LOG_DIR "${CMAKE_CURRENT_SOURCE_DIR}/log")
set(DFM_LIB_VIEWS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/views")
set(DFM_LIB_CONTROLLERS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/controllers")
set(DFM_LIB_MODELS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/models")
set(DFM_LIB_INTERFACES_DIR "${CMAKE_CURRENT_SOURCE_DIR}/interfaces")
set(DFM_LIB_INTERFACES_PLUGINS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/interfaces/plugins")
set(DFM_LIB_INTERFACES_CUST_DIR "${CMAKE_CURRENT_SOURCE_DIR}/interfaces/customization")
set(DFM_LIB_INTERFACES_PRIVATE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/interfaces/private")
set(DFM_LIB_INTERFACES_VFS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/interfaces/vfs")
set(DFM_LIB_INTERFACES_VFS_PRIVATE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/interfaces/vfs/private")
set(DFM_LIB_BLUETOOTH_DIR "${CMAKE_CURRENT_SOURCE_DIR}/bluetooth")
set(DFM_LIB_MATEINFO_DIR "${CMAKE_CURRENT_SOURCE_DIR}/mediainfo")
其中 DFM_LIB_LOG_DIR、DFM_LIB_VIEWS_DIR等变量
message("message output 3DPARTY_DOCTOTEXT_SRC " ${3DPARTY_DOCTOTEXT_SRC})
message("message output 3DPARTY_CHARSETDETECT_SRC " ${3DPARTY_CHARSETDETECT_SRC})
message("message output 3DPARTY_UNZIP_SRC " ${3DPARTY_UNZIP_SRC})
message("message output 3DPARTY_MOZILLA_SRC " ${3DPARTY_MOZILLA_SRC})
其中 "message output 3DPARTY_MOZILLA_SRC " 与 ${3DPARTY_MOZILLA_SRC}的区别
add_library (${PROJECT_NAME} SHARED
${3DPARTY_WV2_SRC}
${3DPARTY_FSEARCH_SRC}
${3DPARTY_TEXTSEARCH_SRC}
${DFM_LIB_DFM_USERSHARE_DIR}
${DFM_LIB_DFM_DIALOGS_DIR}
${DFM_LIB_DFM_CNPINYIN_DIR}
${DFM_LIB_DFM_UTILS_DIR}
${DFM_LIB_DFM_FILEOPERATIONS_DIR}
${DFM_LIB_LOG_DIR_SRC}
${DFM_LIB_VIEWS_DIR_SRC}
${DFM_LIB_CONTROLLERS_DIR_SRC}
${DFM_LIB_MODELS_DIR_SRC}
${DFM_LIB_SHUTILS_DIR_SRC}
${DFM_LIB_INTERFACES_DIR_SRC}
${DFM_LIB_INTERFACES_CUST_DIR_SRC}
${DFM_LIB_INTERFACES_PLUGINS_DIR_SRC}
${DFM_LIB_INTERFACES_PRIVATE_DIR_SRC}
${DFM_LIB_PLUGINS_DIR_SRC}
${DFM_LIB_GVFS_DIR_SRC}
${DFM_LIB_DBUSINTERFACE_DIR_SRC}
${DFM_LIB_QRC_FILES}
${DFM_LIB_IO_DIR_SRC}
${DFM_LIB_VAULT_DIR_SRC}
${DFM_LIB_TAG_DIR_SRC}
${DFM_LIB_VAULT_QRENCODE_DIR_SRC}
${DFM_LIB_IO_PRIVATE_DIR_SRC}
${DFM_LIB_DEVICEINFO_DIR_SRC}
${DFM_LIB_MATEINFO_DIR_SRC}
${DFM_LIB_BLUETOOTH_DIR_SRC}
${DFM_LIB_INTERFACES_VFS_PRIVATE_DIR_SRC}
${DFM_LIB_INTERFACES_VFS_DIR_SRC}
其中广泛使用的 CMAKE_CURRENT_SOURCE_DIR
find_package(Qt5 COMPONENTS Core REQUIRED)
find_package(Qt5 COMPONENTS Gui REQUIRED)
find_package(Qt5 COMPONENTS Widgets REQUIRED)
find_package(Qt5 COMPONENTS Network REQUIRED)
find_package(Qt5 COMPONENTS DBus REQUIRED)
find_package(Qt5 COMPONENTS Sql REQUIRED)
find_package(Qt5 COMPONENTS PrintSupport REQUIRED)
find_package(Qt5 COMPONENTS Svg REQUIRED)
find_package(Qt5 COMPONENTS Concurrent REQUIRED)
find_package(Qt5 COMPONENTS LinguistTools REQUIRED)
find_package(Qt5 COMPONENTS Multimedia REQUIRED)
find_package(Qt5 COMPONENTS MultimediaWidgets REQUIRED)
find_package(Qt5 COMPONENTS X11Extras REQUIRED)
find_package(Qt5 COMPONENTS Xml REQUIRED)
#Should You check package version,if want control the any package version. used old pkg-config
find_package(PkgConfig REQUIRED)
pkg_check_modules(PKGS REQUIRED
libsecret-1
gio-unix-2.0
poppler-cpp
dtkwidget
dtkgui
udisks2-qt5
disomaster
gio-qt
libcrypto
Qt5Xdg
libmediainfo
liblucene++
liblucene++-contrib
libxml-2.0
htmlcxx
libgsf-1
glib-2.0
dframeworkdbus
其中解释说明 #Should You check package version,if want control the any package version. used old pkg-config
首先CMake和环境配置。
其次设置生成目标。
最后设置安装路径。
